Broken valve stem
Old Nov 22, 2016 | 04:34 PM
hansomeden's Avatar
Default Broken valve stem
I have a set of AFR 215 heads that have done 4000 miles.Recently at a track day the car developed a bad miss,I thought it might be electrical but after a bit of searching I discovered that an exhaust valve stem had broken At the top groove where the locks fit,lucky the valve didn't drop into the cylinder.I was wondering if this has happened often or is just a one off?
Old Nov 23, 2016 | 05:59 AM
vettenuts's Avatar
Not sure on the AFR valves, but the stock valves have a welded tip. I would either contact AFR or for a better answer shoot a PM to Tony Mamo.
Old Nov 23, 2016 | 03:04 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Contact AFR....they will get you sorted out
Try to take some good photos and call their Sales Dept. They are still open today if you have the chance
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
