What material is the steam tube made of?
Old Nov 24, 2016 | 09:02 PM
CasperCasper's Avatar
Default What material is the steam tube made of?
Hi all,
This may sound nuts but what material is the lq4 steam tube made of? Reason being I drilled and tapped my stock steam tube fittings for 1/8 NPT and now want to weld the tubes shut. I am essentially making this out of the steam tube:
http://www.ebay.com/itm/V34-Steam-Ve...-/131253503877
The tube ends are magnetic but seemed to drill way too easy, are they steel or am I going nuts here? I want to tig but may use silver solder. I am in Canada and those fittings are weeks away.
Old Nov 25, 2016 | 08:15 AM
truckdoug's Avatar
yeah its zinc plated mild steel
Old Nov 26, 2016 | 01:57 PM
MY_2K_Z's Avatar
Why do you want to weld them shut.
Old Nov 27, 2016 | 08:28 AM
truckdoug's Avatar
I gather he's tapped the tops for npt to AN fittings and will connect them that way until the fancy parts arrive.
