what could cause this main bearing failure?
NO "mains" are ALL .0025", some kind of story ?
I see no "good" marks from the bearing tangs on the complement shells.
I may see, from the pictures, that #1 and #5 are marked.
My memory is that LS mains "kiss" the Tangs.
Did you mark the main direction, not the order ?
I also observe very HOT oil temperature.
Lance
I would suspects possible assembly error.
How does the rest of the crank look?
How do the bearings in the block look?
What do the rod bearings look like?
Im going to have another machine shop verify my findings just to make sure but i believe it was an error when the crank was cut. I just find it hard to believe my previous machine shop could not find this runout that i just found.
Likely, they ground it, knocked the fuzz off, and called it good. Shitty workmanship is easy to "find"...
As mentioned: A new crank, from a shop that knows WTF is going on.
NOW this could be possible with a VERY LARGE bearing/journal clearance.
I ask for the Bearing Manufacturer, Part #, and Journal Size ?
Lance
I will take the time to measure, again, what I have on hand.
My observation states that the "thrust" has the witness marks of incorrect direction.
The pictures you gave might just be miss-giving.
Could you picture the Block Thrust center area ?
Lance
Really need to see the block side of things too.
I used to grind crankshafts and can say it's very difficult to cut the mains off center. Once the crank is centered in the machine and zeroed all 5 mains are cut in succession, usually with a steady rest on the #3 main. These are usually cut after the rods to avoid any relieving of the metal when the rods are cut to ensure a straight shaft.
However, the best cut crank in the world is useless in a block that doesn't have straight mains, which is what this looks like to me.
