It's Alive!!
Old Dec 6, 2016 | 08:56 PM
AnimeFunTV's Avatar
Default It's Alive!!
cue Ace Venturea haha
Well after close to 4 years, my LQ4 6.0L finally runs!!
However I have one pretty big problem, she won't idle on her own. If you listen carefully I hold the throttle steady and you can her her surge and as I lower the throttle more and more she just doesn't idle and just dies.
I have already plugged all the vacuum ports prior and even did vacuum smoke test and nothing major is leaking. Any idea's?
Old Dec 7, 2016 | 10:15 AM
gagliano7's Avatar
Probably the short exhaust . It needs full exhaust to work properly.
Old Dec 7, 2016 | 01:19 PM
pozesd99''s Avatar
Has the computer been tuned for the aftermarket cam etc?
Old Dec 7, 2016 | 01:34 PM
Ls1Ryan2002's Avatar
+1 what Pozesd99 said, if it hasn't been tuned that's more than likely your problem.
Old Dec 12, 2016 | 01:22 PM
Mercier's Avatar
Add to that ported heads, car intake, 4-bolt TB, surely different injectors.. You need a completely different tune. What did Howell tell you they put in there for you? Was the tune supposed to work with those mods or was it a generic 6.0 tune?
