Ls1 camaro threw a rod on cold start?!
But it's definitely a hydrolock issue from rain making it into the motor. Sorry.
Also, when you say intake lid, which one. If the filter is exposed that could of been the reason.
I discovered this early one morning after it rained overnight. I went to start my Formula and it started to crank then slowed down then BAM it started funny. I thought WTH just happened??????? When I tried to restart it no problem started normal but I knew something crazy was going on. SO I popped the hood and discovered the engine was all wet??????? I'm thinking WTH??? why is it wet?????
I closed the hood and got a gallon jug of water then poured it on the windshield...........popped the hood and discovered Niagara Falls dripping all over the engine. I then started looking for the source of this and found the cowling IS NOT sealed so any water just drips onto the engine!
Now its a lot more to sealing this cowling then you would think and it has to be carefully done because even one little tiny water leak can lead to engine carnage.
BE SURE TO TEST IN THE RAIN AFTER YOU DO THIS, WHEN YOU OPEN THE HOOD NO water should be on the engine or dripping onto the engine.
Believe it or not the new Camaros use a plastic cover over the engine to stop this maddnessssssssssssssssssssssssssssssssssssssssssss sssss
I really don't care what you all think or believe and I'm not going to hash over this. Read my post and do as you like. Good Luck
