Do I need a new crank seal??
Old Jan 22, 2017 | 02:47 PM
irocbob's Avatar
Default Do I need a new crank seal??
I have a 02 LQ4 build I'm working on and I got a new engine stand so I moved the short block from one stand to another, and while on the cherry picker the engine tilted forward and oil started coming out from the crank seal area.. not a whole lot but a noticeable amount
I've noticed in previous situations when there's a lot of pressure on a seal it will seep out some fluid, but is perfectly fine when all that pressure that was leaning on it is gone.. is this one of those cases or is my crank seal bad?
Old Jan 23, 2017 | 06:54 AM
gagliano7's Avatar
Are you sure the oil didn't come out of the flywheel bolt holes?
Old Jan 24, 2017 | 01:44 AM
irocbob's Avatar
Positive, i'm talking about the front crank seal sorry for the confusion
Old Jan 24, 2017 | 11:33 AM
svslow's Avatar
If the front cover is misaligned the seal will leak.
