best heads and cam
Old Jan 25, 2017 | 10:49 PM
Ammar Al-ansari's Avatar
Default best heads and cam
Hi all.. hoping to find an best heads and cam for camaro ls1 .. with the head gasket.. enging is 5.7 .. which one u suggest guys ..
Old Jan 25, 2017 | 11:08 PM
stockA4's Avatar
Just like the universe, your LS build is an infinitely variable horsepower equation. Do your own research and read every cam catolouge and engine build write-up you can find. We live in a world where the information we need to make educated decisions based on quantifiable data may always only be a few mouse clicks away.
in case you were wondering there are to many variables, even within similar combinations for their to be a "best" setup. A few degrees here or there on the camshaft, or a few cc"s in the combustion chamber may likely get lost in the "noise" of inherent variability. it just isn't as significant as you may think.
Follow your gut and we'll See you at the drag strip ;-)
Old Jan 26, 2017 | 03:55 AM
07NBSChevy's Avatar
This is like asking "What is the best tire". Like said above, there is hundreds of difference options and combinations you can go with. Now everything will have a specific purpose and you will need to figure out what you intend to use the vehicle for. Is it Drag racing, Daily, Weekend Racer/Daily, Crazy lifted 4x4 LS1 Camaro for muddin. You also need to figure out if you have any plans for boost in the future or you just want heads and cam.
A good start for stock heads is having TSP-PRC do some porting, this is affordable and you will notice the gains. Then there is companies like Mamo, Dart, AFR, and so on that have CNC-Machined aftermarket cylinder heads and each have different flow rates that will work best with certain cams, certain HP goals and so on. You can not use 260cc heads with a 212/218 cam and expect 100 hp gains and peak numbers at 2000rpm.
Larger cams will also require other supporting mods such as Dual Valve springs with certain Open/Closed springs pressures, Auto cars will need a higher stall converter, as well as a few other things.
Can you tell us what goals you have in mind, HP wise, as well as future plans such as boost, and what the car will be intended for? Also, what is your budget on this?
