2002 camaro lifter tap until warmed up
I went and got another Ls1 Camaro a 2002 B4C last month. Test drove it ran and drove perfectly. Or so I thought. It was already warmed up when I got it. So I never heard what I guess is lifter noise. Until it warms up it gets top end engine noise. The car still has plenty of power. Just wonder what to do about this. I'm uploading a video to YouTube now.Will add once complete.
this car did sit in a shop for 10 years . so I'm wondering if its just grime I need to flush out .
https://www.youtube.com/watch?v=kDHw...ature=youtu.be
Good luck!
GM says any engine noise that goes away after 2 mins is normal. Another thing you can try is add a few ozs of TransX to the engine oil. It will clean any crap that is in the lifters but I honestly don't think it will help in your case. You just have poorly built lifters, the internals were not properly matched so they leak down to quickly. GM also did this for more performance.....the quicker the lifter bleeds off the faster the valves close completely. Its a double edged sword.
I also hear piston noise in your video which is completely normal, between the 2 noises I know it sounds bad BUT my WS6 sounds exactly the same from day 1 and has 140k on it now....still sounds the same. Just left it warm up for 2 mins before driving it cold and you'll never have trouble.
There is something you should try is to run a top engine cleaner to clean the built up carbon from the piston tops. The built up carbon can cause cold piston knock because the engine shrinks enough cold that the carbon can touch the heads. Once the engine is hot the engine expands and the noise disappears< this may be your biggest issue.
Russ Kemp
