Looking for cam help 02 ws6
Old Feb 25, 2017 | 10:23 PM
jeffro51's Avatar
Default Looking for cam help 02 ws6
I currently have a 02 ws6 m6 and is basically stock, just tsp rumbler catback. I am planning on new tsp longtubes with off-road y pipe and was looking for help on a cam/valvespring selection. I was planning on keeping stock heads but would change timing chain and oil pump in the process. Just didn't know how aggressive I could go to being stock as it is. My car doesn't get drove much. Just on nice days so I try to keep it nice but just finally wanting to do some upgrades. I do like the more "rough idle" approach but just looking for help
Old Feb 26, 2017 | 11:40 AM
RollinSScamaro's Avatar
I'd say something in the 228 to 232 duration range.. I'm sure the cam motion titan 4 will come up a few times.. there are so many options it will make your brain hurt.. with stock heads I just wouldn't go too crazy on the cam so it stays fun to drive.. 112 lSA for a 6 speed.. smaller cam will help with valvespring life too.
Old Feb 26, 2017 | 02:09 PM
sxc Z28's Avatar
Titan 4 or BTR Stage 2. .660'' Tooley Double Springs w/ Titanium Retainers. Timing chain and oil pump as you said and I would add an ATI balancer while you're already there anyway and a good tune you should be good.
Old Feb 26, 2017 | 05:51 PM
TXZ28LS1's Avatar
TSP 228R
TSP Torquer 2 232/234
Speed inc SI5 231/237
TSP 233/239
Good all around size cams thats easily daily drivable and still make good power..
Old Feb 26, 2017 | 07:58 PM
02sunsetorangeZ's Avatar
tick sns stage 2. either ls1 or ls2 version depending on how you want, i went with ls2 version
Old Feb 27, 2017 | 10:26 AM
farmington's Avatar
what gear? what trans? A4 converter? all need to be known before selecting a camshaft
Old Feb 27, 2017 | 12:40 PM
Martin Smallwood's Avatar
A great camshaft I like to use for applications like yours is a 230/234 .612/.595 112+2. This camshaft has a great idle, drives well and makes great mid-range and top end power without sacrificing a ton of bottom end.
I also would recommend BTR .660" Platinum spring kit with titanium retainers, 5/16" push rods, ARP cam bolts, ARP crank bolt, Timing cover seal, gasket and water pump gaskets. Also an IWIS timing chain, Melling HP oil pump and a Straub bushing trunion upgrade kit.
This is what I consider a complete cam swap package that has every part you will need and some.
Old Mar 2, 2017 | 07:07 PM
jeffro51's Avatar
Stock gears and 6 speed
Old Mar 2, 2017 | 07:09 PM
jeffro51's Avatar
Are these products you offer
Old Mar 2, 2017 | 07:11 PM
MonmouthCtyLS7's Avatar
Martin knows his ****.
Old Mar 3, 2017 | 01:01 PM
Yes they are! I'd be glad to get you some pricing if you would like to call or email me.
Old Mar 11, 2017 | 02:47 PM
jeffro51's Avatar
Sent you an email. Thanks again
