shops
Old Mar 19, 2003 | 06:34 AM
muscratmauler's Avatar
Default shops
Any of these speed shops for our cars in the Reading, PA area (about an hour NW of Phily)
That can tune?
Mine was done, but they only did 3 pulls and said that was it. that's all it will make.
They didn't take care of the idle either.
What really has me IRRITATED is they gave me a set price and said no matter how long it takes.
I was there all day and they only tuned for the last not even an hour. They were closing and wanted to get out. I did have a problem with my car I had to work on, which took some time, but I waited 4 hours before they even pulled it in.
I made 422 & 390 at the wheels, and I expected more.
"CNC" LS6 2.050/1.60, 11.4 compression, 224/228 .581/.588 112lsa (XE-R), QTP 1 3/4" headers, Random Tech. Metallics, 3" y-pipe into 4" collector, Mufflex 4" exhaust with Spinteck muffler and dual 3" outlets, Bauer throttle body, bellows, lid w/K&N, BG ram air, Cartek clutch, SLP billet steel flywheel, stock rear, 3.42, girdle.
Other than the air/fuel ratio, I don't know what else they could have tuned. Which I could see only needing a couple pulls to get right. They told me adding timing won't do anything cause these motors are so effecient.
I have to stay on the gas to keep it running when starting in, bucks like a mule.
any help apreciated
thanx
<small>[ March 19, 2003, 07:14 AM: Message edited by: muscratmauler ]</small>
Old Mar 19, 2003 | 06:57 AM
GoFastTurnLeft's Avatar
Default Re: shops
Where did you go? Mike at Rapidmotorsports has done tuning for several ls1 owners I know, and does a great job. He's also a site sponsor.
Old Mar 19, 2003 | 07:19 AM
99MONGOOSE's Avatar
Default Re: shops
I also would check with Rapid Motorsports, unless thats where you originally went? Is that the case? Cartek isn't very far from you is it?
Old Mar 19, 2003 | 08:56 AM
JPR's Avatar
JPR
Default Re: shops
Rapid MS and Cartek are the only 2 I know of besides F-Body Central that do steady edit dyno tunning, I think if you feel you were rushed through a session, there may be some more left in it fine tunning the curves? Well, good luck and check out thoses Vendors above.
Joe.
Old Mar 19, 2003 | 08:57 AM
Default Re: shops
It was not Rapid, but if you take another guess, you'll have it
I don't know much about Rapid. He is however very close. 15-20 min. Does he have a dyno? All I know of him is he uses ARE heads.
thanx
Old Mar 19, 2003 | 03:58 PM
Default Re: shops
Mike uses a dyno in Pottstown, which is also very close. Do yourself a favor and call him.
Old Mar 19, 2003 | 04:05 PM
Default Re: shops
Just out of curiosity, what was the difference between your first pull and your last pull?
Old Mar 19, 2003 | 06:33 PM
Default Re: shops
difference was 10-11 rwhp & 5 rwt
Does anyone know Rapid's #?
thanx fellas
Old Mar 19, 2003 | 09:34 PM
JPR's Avatar
JPR
Default Re: shops
Here is his link...
https://ls1tech.com/ads/rapid.gif
Joe.
Old Apr 26, 2003 | 12:57 PM
ScreaminSS01's Avatar
Default Re: shops
Did you get your car straightened out?Mikey tuned my car and I am very pleased.If you didnt get his number yet its 610-404-7979.He will help you out.Good luck.
Old Apr 27, 2003 | 08:08 AM
Default Re: shops
No, my car is not straightened out yet, low r.p.m. driveability sucks idle is not right.
I did call Mike at Rapid, but he wants $450 plus I have to rent the dyno. That's not bad price, but considering I already paid $550 to Cartek (for 3 pulls and no idle or driveability tuning and being there from 12 noon till about 7:30 at night)I don't want to spend that much more again.
I AM VERY IRRITATED, I don't know if you have to buy there heads for them to care or what, but I spent a lot of money on parts there and all I got was:
1. initial pull
2. leaned out top end (pull 2)
3. leaned out midrange (pull 3)
THAT'S IT!!!!!!!!!!!!!
no playing with the timing, no fixing idle, car wouldn't even stay running when they pulled it off! And Dave told me "$550 for as long as it takes" and if the mass air sceen needed to come out or bigger injectors were needed, all that would be done. They would take care of the idle, driveability, WOT.
BUT, I just got the above, HELL, I didn't even get my air/fuel ratio
Alright, enough bithin. With what I stated above about the 3 pulls. Does anyone think there could be more in it. I know the idle can be fixed.
any help is GREATLY appreciated!
Old Apr 27, 2003 | 09:27 AM
chris98pace's Avatar
Default Re: shops
I just had my car tuned thorugh jason at F-body central. 13 pulls. Left very very pleased.
Old Apr 28, 2003 | 08:15 PM
Default Re: shops
ttt
Old Apr 29, 2003 | 07:40 AM
Reckless's Avatar
Super Moderator
Default Re: shops
It's kind of irritating to go through that. But I have tuned cars in as little as 3 pulls. Just depends on how lucky you get with your numbers when you tweak.
Could you please reduce or turn off your signature? That is also very irritating for some
Old Apr 29, 2003 | 04:37 PM
Default Re: shops
I want to not have my sig. apear except when I want it to, but this new board, I looked but could not figure out how
