Ls2 with ls3 top end, ptv clearance
Old Mar 4, 2017 | 09:35 AM
Zamarripa493's Avatar
Default Ls2 with ls3 top end, ptv clearance
im sure you guys have seen this numerous times but I can't get a good answer. Ive got an ls2 along with ls3 heads (0821 cast heads), I'm having a hard time finding out what the max cam lift is without having to fly cut the pistons. Heads are not milled or anything but I will be installing dual valve springs for the cam. Thanks any info is appreciated.
Old Mar 4, 2017 | 09:46 AM
Darth_V8r's Avatar
Moderator
Lift has zero bearing on PTV. It's duration. At TDC, depending on duration, valves are closed or nearly closed. At peak lift, you're at 106-120 degrees past TDC, which means the piston is an inch and a half away from the valves at least.
You can have a 250/260-110 cam with .500 lift that'll have PTV contact. You can have a 210/220-120 cam with .800 lift that'll clear with room to spare
Old Mar 4, 2017 | 09:51 AM
Sorry I'm a rookie to all this lol.
So don't worry about lift, only duration?
Old Mar 4, 2017 | 10:02 AM
cam specs are 230/238 @.618
Old Mar 4, 2017 | 10:08 AM
coltboostin's Avatar
Put a head on and clay it. Only way to know with 100% certainty
Old Mar 4, 2017 | 10:16 AM
Darth_V8r's Avatar
Moderator
Correct
What LSA? Tighter LSA means more cause for concern. If your LSA is 112 or higher you're probably fine.
Exactly. But make sure you use a solid lifter so it does not collapse from the clay and give a false large reading
Old Mar 4, 2017 | 10:29 AM
Correct
crap it's a 109 lsa.
Old Mar 4, 2017 | 10:54 AM
Darth_V8r's Avatar
Moderator
You might still be ok. But you need to do the clay
Old Mar 4, 2017 | 01:28 PM
thanks for the 411
Old Mar 4, 2017 | 03:24 PM
speedtigger's Avatar
Old School Heavy
What is the intake centerline on the cam card?
