To mill or not to mill. That is the question.
I totally missed that this is going in a truck. I can speak from direct personal experience. I have the LS6 cam in a suburban, and I hate it. The power comes in too late. I fell prey to the hot rod magazines, which I've learned to ignore. If I could do it over, it'd be a 214/224-112+4. Run that with .550 lift, and you can use the stock LS6 springs, lifters, and probably even the pushrods.
Edit - I'm not talking about the S10 in my sig. That thing is light enough that the LS2/LS6 cam is fine
I just wanted info on milling, but 'tis the internet...... Doing a valve job and bowl work as well. Plus long tubes and true duals. It may not pull hard from 600 rpm but I don't need it to. And it will scream just fine past 3,200.
Yeah, and the half inch wide profile pic shows off what's in the picture very well. When the pic is that small guess what? It's a pic of your truck with the lights on and that's it. Cool lights though bro. Wish I had headlights.
