Diamond R-Series Pistons
Apparently, they include the piston rings now (1.2/1.5/3mm or 1.2/1.2/3mm rings that are Total Seal AP Stainless Top Rings in some applications), moly coated side skirts, .250" ringland depth, and decent .185" wrist pins. Also, have the option of going to H13 Tool Steel Wrist Pins as an upgrade.
The pricing is also very good on these.
I'm now looking at the 11503-R1 for my build and the pricing is under $900 for the set with the H13 wrist pins.
Just thought I'd share for anyone looking for another piston option.
From Diamond:
3D milling on piston crowns for ready to install finish
Valve pockets designed to work with most aftermarket cylinder heads
Offset pins for quiet operation
Moly skirt coating for friction loss and skirt wear protection
Top ring down dimension: .250"
Premium 1.2mm x 1.2mm x 3.0mm ring package included
Premium 1.2mm x 1.5mm x 3.0mm ring package on all 3.905 bore piston sets included
Premium 8620 .185W wrist pins included
Valve pocket depth: 0.176" intake and .105" exhaust
2618 material for High HP-NOS-Boost applications
my builder told me they come standard with the coating and .250 wall H13 pin.
These are are also known as the LS2K pistons because diamond rates then to 2,000 hp.
