my setup .. + questions
Old Mar 9, 2017 | 12:41 AM
sisqo_dashti's Avatar
Default my setup .. + questions
i have ls1 5.7 stock bottom on firebird 01
My setup
- ported ls6 intake
-tb ported
-slp lid
- long tube headers + y + Lm1 exhuast
- 243 ported valve 2.02 1.6
-Chevrolet Performance Hydraulic Roller Lifters 12499225
- btr cam stage 1 223/230 573/610 115
- spring valves 660 lifts
-melling oil pump 10296
- stock gm heads gaskets 0.51
*What pushrods length should be good with this setup?
*what timing chain should be good without changing cover and issues ?
Old Mar 9, 2017 | 10:45 AM
SiskMan's Avatar
Youll have to measure pushrod length yourself. There is no real formula unless you have unmilled OE heads with a cam and stock lifters. Even then you should measure to be safe.
Ive always ran the GM LS2 timing chain and never had any problems.
Old Mar 9, 2017 | 12:04 PM
The heads actually is milled !
About timing chain that no need to change gear ? Only ls2 chain ?
And can i have the part number ?
Old Mar 9, 2017 | 05:34 PM
Up up up
Old Mar 9, 2017 | 05:36 PM
Darth_V8r's Avatar
Moderator
Cloyes 3220 timing set
Old Mar 9, 2017 | 10:40 PM
thank you ,, it will be fit with both cloyes Sprocket ?
Old Mar 10, 2017 | 03:42 AM
07NBSChevy's Avatar
You should always measure for pushrod length, COMP has a good checking tool for relatively cheap. I have always used LS2 timing chains in my builds. LS2 Timing chains are stout for mildly built engines. If there is any wear on your lower sprocket, it wouldn't hurt to swap in a new one.
Old Mar 10, 2017 | 01:23 PM
Darth_V8r's Avatar
Moderator
That cloyes part number is the full set. Gears included
