G5X2 cam with 5.3 heads? Will it fit?
The heads are 5.3 TEA Stage 2's milled 10 thousands for 10.8:1 compression ratio. Would you guy's think the G5X2 cam would fit? It's a 232/240 .596/.609 112 which is a big *** cam. I'd love to run the cam but I think it would be too big for piston/valve clearance issues. Thanks everyone.
Richard Donovan Farrell
Re: G5X2 cam with 5.3 heads? Will it fit?
I would think being milled at .010" you are getting pretty close to the borderline on PTV clearance with that cam. Just my $.02
Mike
Mike
Pull the #1 intake valvespring off with the motor @ TDC. Send me an email on me how far the valve "drops" into the cylinder, before hitting the piston and I can tell you if it will fit. A dial caliper will be necessary. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
If it doesn't clear you can notch the pistons. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
<small>[ March 19, 2003, 09:39 AM: Message edited by: Godspeed ]</small>
he ended up going with a 230/230 .590/.590 110... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
(yellow C5 verts are <img border="0" alt="[rainbow]" title="" src="graemlins/gr_rainbow.gif" /> )
