H/C Install checklist with a few questions
CURRENT MODS
- Speed Engineering 1 3/4 Longtubes
- SLP LM1 catback
- P&P Throttlebody
- SLP Lid
- Mail in Frost Tune
- Upgraded to 3.23 gears from 2.73
CURRENTLY HAVE PARTS LIST
- Stage II 4l60e racing transmission ($1,500)
- 3200 TCI Stall
- 243 heads
- Poly Motor&Transmission Mounts
LOOKING AT PURCHASING
- Torquer V2 Cam
- LS6 Oil Pump (is this recommended?)
- LS2 Timing Chain (recommended or required?)
- Transmission Cooler
- Gasket Kit
- 36 lb fuel injectors (I assume I'll need bigger injectors for this cam?)
- New catback, haven't decided, but LM1 with a V2 Cam will probably sound like ****, I'm open to suggestions really. I would like to add an electric cut out to the catback as well.
- 160* T-stat (I'm in Indiana, but the car will only be driven in the spring, summer, and fall. Recommended?)
- Full engine rebuild. (My rear main seal is leaking, and for $1,500 I know a guy who will completely rebuild the engine and add the cam and all the other goodies at no additional cost. So it's not just a cam and heads install, but an engine rebuild as well.)
- Good Dyno tune.
I have a set of Brian Tooley springs lined up, haven't purchased them yet. I also need to find a set of hardened Pushrods.
So this is my list and how far along I am so far. Anything else you guys would recommend? Do all of these mods and adds sound worthwhile? Should I also add a larger/stronger fuel pump? I've found some cheap fuel injectors on Ebay, Bosch 36lb injectors all 8 for $99, they're refurbished. Not sure if I should take a chance on those or not.
I've heard I also may as well replace the spark plugs while in there. Am I missing anything and does this combo sound good? Just shooting for a brand new tranny and motor for a car that will spend 98% of its life on the streets, with maybe 3-6 track runs a year, that's it.
