370 LQ4, Build Questions
I'm most likely using Wiesco flat top pistons (-3.2cc 4.030) and 799 heads that been milled .003" and a valve job. The reason I only had them milled .003" is because I was originally using them for a stock ls1 but the build went a different direction. Do I have more milled off of them to bump compression? Also using K1 H-Beam rods (6.125"). The cam is a BTR stage 4, with all the supporting mods (pushrods, LS7 lifters, BRT dual springs, comp cams trunion bearing upgrade, milling oil pump, slp double-rolling timing chain).
What head gaskets do you recommend?
What size injectors? I may run nitrous in the future, but not this year. Leaning towards the 42 lb. Racetronix. Or do you recommend anything else?
Sorry for all the questions, first build so I want to make sure I'm doing it right before I spend even more money. Thank you in advance.
42' s are perfect, use a Bronze bushing trunion kit, is that cam ok for stock rockers?
Also, you might consider using a bronze bushing upgrade rather than the Comp one, as the trunnions are showing premature wear in many cases. Just a heads-up....
