When does the PCV become inadequate?
Started up ran fine no leaks, got the fuel dialed in and took it for a drive. When i gave it a good squirt it pushed oil out of the rear main and made a mess.
I changed the rear main (appeared to be nothing wrong with the one that was in it - brand new and installed correctly). Both times a felpro rear main was used.
The engine did the same thing next time i got into it.
I took the oil cap off and had another spirited drive, this time there was no problem so i suspect the crankcase is getting pressurized and causing this.
The LS6 valley PCV i used was from a low km motor and i also cleaned it as best as i could with degreaser before installing it.
Im not sure where to go from here, the friend who built the motor with me thought it might have been building pressure because the rings arent fully bedded in yet (motor has done maybe 30 miles) but i have never come across this before.
I am after some ideas and also some further insight into when the stock PCV system becomes inadequate. I searched and read a lot of threads but was unable to find any clear information on this, i also saw a number of engine builders recommend upgrading the stock pcv system. Is it comp?, bigger ring gaps? or what that causes the stock system to be inadequate?
I will comp test the motor to eliminate doing something silly like putting a ring in wrong and i had wondered about pulling off the valley and checking the pcv isn't blocked, but i could suck air through the PCV and i imagine with the strong vacuum pulling it its certainly not blocked.
There is a decent bit of oil in the intake too but i have thought this pretty normal with LS engines.
Another option you can try is getting a 1-way-out (only lets air out, not in) breather to replace the oil cap (rx makes these for example). Since you didn't have the issue with the oil cap on then at least this should work for you if nothing else it can be a bandaid.
As for the oil you need a good catch can on the dirty line and possibly one for the clean line. For the clean line another possible option would be a to put a one way check valve there only letting air out of the throttle body into the crankcase and not back up, BUT make sure this is paired with the oil cap breather as well so pressure can be vented somewhere.
Plan from here is to run it in a bit make sure the rings are doing their job 100%, test it, put the cap back on, test it, if it leaks clean/replace the pcv, test it and if that all fails catch can
still keen to know when and why the stock pcv becomes inadequate
If you're sure the system is routed correctly and you've checked the hoses and the LS6 valley cover and there are no blockages, then it sounds more like a problem with the shortblock than an inadequate PCV system. Beefing up the PCV may just be a band aid for the symptoms of excessive blow by.
that connection has yet to be mentioned here. for this engine it would be passenger forward valve cover port to top of the throttle body. this is where blowby exits at full load, ahead of the throttle blade
is your stuff correct and not plugged or even partially blocked?
as mods pile up and power increases, the %leaked to the crankcase continues to add up, and unfortunately this is not intuitive for most, and they have a problem before they know it. the crankcase breathing ability needs to grow with the flow you are trying to manage through it
my systems add larger, or even multiple exit points to ensure pressure is never allowed to build, and can shut back down to operate a normal pcv path otherwise.
