valve spring recommendations
Old May 1, 2017 | 12:00 PM
2002redrado's Avatar
Default valve spring recommendations
i'm in the process of swapping a 5.3, i'll be running a howards 226/234 rattler cam .525/.525 lift. just looking around for recommendations on what valve springs I should run? thanks In advance!
Old May 1, 2017 | 12:27 PM
ported polished 215 heads, comp performance rocker arm trunion upgrade, performance hydraulic roller lifters, comp hi-tech pushrods, LS2 intake, dynatech headers
Old May 1, 2017 | 03:56 PM
thatoneguybriz's Avatar
I know PAC 1218s are a good choice for under .600 lift and are relatively cheap.
Why not speak to Howard's tech line and have them sell you a spring kit matched for your camshaft?
