damaged crankshaft
Old May 12, 2017 | 10:47 PM
gasfish's Avatar
Default damaged crankshaft
I have brought an 5.3 ls i knew it was damaged but on the crankshaft the reluctor ring had some damaged teeth and plus how can i select the right crank shaft to replace it with
Any help will be a big help
AGV
Old May 12, 2017 | 10:51 PM
If ONLY the reluctor ring is damaged it can be replaced. A machine shop job, though....
Old May 15, 2017 | 09:44 PM
99wssixm6's Avatar
5.3 cranks are $100-200 max. You may want to look for a replacement. Thats a lot of work to get the ring off a few degrees.
Old May 16, 2017 | 01:09 AM
64post's Avatar
To get the old one off, use a bottle of MAP gas if you don't have access to an acetylene torch, heat it up until you see some red then tap it off with a brass hammer. Then you need the Goodson reluctor indexing tool to install another.
