LS1 BLOCK vs LS6 BLOCK
you can view the thread here:
http://www.z06vette.com/forums/showt...145#post294145
and here is a pic of an ls6 block showing the notch that i got from a member on Corvette Action Center Forums
as you can see in the pic the notch on the LS6 is just like on my block <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img src="http://images.cardomain.com/installs/208000-208999/208274_21_full.jpg" alt=" - " />
as for your thread, thanks.. Ive been looking for a LS6 pic to see the difference. As for someone saying that the LS6 block as the "windows" so do I. Its a round hole bored between the cylinders and I have the ol' LS1 block.
But... it does look like some got the LS6 block if your block is a dark grey cast and none of the "bullseye" marks........
My 98 LS1 block casting # 12559846 doesn't. It looks identical to the LS6 block externally except internally it doesn't have the "cast" in window between cylinders.
I even installed the LS6 PCV cover without any modification.
So, does anyone know what the scoop is on LS1 block casting #12559846 and why the casting is different from other LS1's???
https://ls1tech.com/ubb/ultimatebb.p...=000075#000026
<strong> THANKS for the picture. yep.... i've got the notch in my 02 WS6 just like the picture. IT has an AUG.01 build date. as far as the color, guess i'm just going to have to look at another one,like an 2000,or 99. Thanks much, Terry. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I just looked at my Formula which also has an August 2001 build date, and it has the bullseye marks. Oh well, I wish I got the LS6 block, luck of the draw I guess.
98 LS1 Block
<img src="http://www.tech-ls1.com/extras/LS1_12559846.jpg" alt=" - " />
So what's the scope guys? valvegod? engine builders?
Go to the Directory
There is a pic of the "window" at the bottom of the cylinder the pic is blurry, but visible. I also have shots of a few numbers I have found so far. I haven't taken the block out of the box yet but will do if you guys want me to get more pics.
Thanks and hope this helps.
J
PS where can I buy eagle connecting rods?
