LQ4 Questions - How would YOU do it..
I want to build up a LQ4 for my truck i'm looking to get 450-500HP. How would YOU do it?
Junkyard rebuild?
Buy a bare block and build from there?
Buy a fully assembled engine?
Get a short block and go from there?
I know the stock crank can handle the HP but I also know the pistons on the LQ4s are one of its weak points so if i'm going to replace the pistons anyways is it worth getting a junkyard engine?
I have the time and i'm more than capable (at least I like to think that I am). I don't have a set budget but I would like to try and keep it down below 4-5K without the tranny and I want to be able to swap it with my 4.8L and GO. I've been searching and searching for the last week all over forums and I can't make up my mind. Hopefully you guys can help point me in the right direction. I saved up some money and I'm finally ready to start this.
Hope to hear from some of y'all. Thanks
Junkyard rebuild?
Moderator
Received 1,838 Likes
If it were me I'd do Mamo 235 heads, 230/238 cam, tbss intake, dual exhaust, and if it's a clutch fan, convert to electric fan.
Edit - and I'd do something to bump compression
I sent Tony an e-mail to see what a pair of the 235's would cost and I actually was looking at a Lunati Cam the other day with IN/EX @ 230/238. Would you do TBSS over FAST? Thanks for the reply much appreciated.
Find a cheap block or short block. Under 500 if shortblock.
Ls3/l92 heads for 1000 new or cheaper if used.
Ls3 rods/pistons for around 200$
Machine cost to bore etc should be around 300
Throw a carb setup on top and meet your goal.
Moderator
Originally Posted by cnqrthedirt
I actually have this saved. I was looking into doing this just wanted to see what others would say and how they would approach it.I sent Tony an e-mail to see what a pair of the 235's would cost and I actually was looking at a Lunati Cam the other day with IN/EX @ 230/238. Would you do TBSS over FAST? Thanks for the reply much appreciated.
