Pushrod preload to avoid sewing machine noise?
Old Jun 14, 2017 | 05:38 PM
crash41301's Avatar
Default Pushrod preload to avoid sewing machine noise?
Heres the back story...
I had a running Ls1 w/ BTR Stg2 cam. It had oem GM ls7 lifters in it with 7.5 pushrods, and TFS220 heads. It had zero sewing machine noise to it. It was great.
I ended up with a wiped bearing after a road course day due to not realizing that I should run extra oil in the pan due to long sweepers. I ended up rebuilding the engine. The cam was in good shape so I re-used it. I went with Delphi ls7 lifters this time thinking they would be the same thing. I now have a running healthy engine, but with sewing machine noises. Everything else is the same. I thought, ok perhaps its the pushrod length.
Measuring the pushrod I get 7.38 with no preload and being able to rotate the pushrod in place. Ive read that I should aim for .06-.07 preload on the ls7 lifters. That would put me at 7.44-7.45.
So my question is, is that additional .05 enough to cause sewing machine noises? Ive saw some people suggest running .1 preload on them to "avoid excess valvetrain noise". It seems I have excess already. Where should I be trying to set these things? I want my silent valvetrain back that I had before the rebuild!
Old Jun 16, 2017 | 04:08 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
The exhaust lobe acceleration rate has more of an effect than anything. If you didn't have noise before, it won't this time around.
__________________
Old Jun 16, 2017 | 09:01 PM
slogo's Avatar
Do you know if post #6 is correct https://ls1tech.com/forums/generatio...s-lifters.html
Old Jun 16, 2017 | 10:14 PM
If that were true, why do the lifters all have the same part number? If somebody had to replace a lifter there would be different numbers for intake and exhaust lifters. That is not the case.
Old Jun 17, 2017 | 06:42 AM
slogo's Avatar
Yeah, Thank for the response but I wasn't asking the Village Parrot,
was looking for a response from someone with a little Merit.
Old Jun 17, 2017 | 09:21 AM
I forgot, Slogo, logic does not apply to you.... get back on the short bus....
