Can someone verify? ACDelco plug 8#41-110 12621258
I see that a lot of people are using the ACDelco 41-110. Looking at these posts I see most are from 2015ish.
Can someone verify that I have the correct plug? Going in 1998 C5 Corvette. The plug appears to be approx .17" longer from the base to the tip of the spark ground arm than what I am replacing.
Plugs:
Plugs:
GM recommends, for a 1997-2000 Chevy Corvette with the 5.7L Vin G, the Double Platinum Spark plug #41-962 Gapped at 0.040" as the primary replacement. Secondary Replacement being the Rapid Fire plugs #6 gapped at 0.060" and the cheap conventional plugs would be the #R42LTS gapped at 0.050".
They do not list the #41-110 Plugs as a replacement plug. Now they are the same heat range as the #41-962, heat range 5, I would still stick with the #41-962 and gap at 0.040".
