Cam Retainer Plate
Old Jun 20, 2017 | 03:12 PM
70c10's Avatar
Default Cam Retainer Plate
Is this normal to have wear like this?
Old Jun 20, 2017 | 03:51 PM
KCS's Avatar
KCS
Moderator
With an OEM gear, yes. It shoudn't be too deep into the metal though. Basically just the black phosphate coating gets worn off.
Old Jun 20, 2017 | 05:21 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
is that a used cam plate on a new build? I see oil maybe, but that could be assy lube also.
Old Jun 20, 2017 | 06:33 PM
70c10's Avatar
​​​​​​ there isn't a Groove, it's just the coating wore off. Thanks for the input just wanted to double-check.
Old Jun 20, 2017 | 06:34 PM
70c10's Avatar
is there a problem reusing the plate? The motor only had 32,000 miles on it when I tore it apart. And you are correct it is assembly Lube.
Old Jun 20, 2017 | 10:02 PM
A new one is only $18 why reuse it? that seal can only be compressed once really. its what seals off the front lifter gallies from leaking. Plus it wears on both front and back.
Old Jun 21, 2017 | 06:38 AM
vettenuts's Avatar
As I recall there is an inspection procedure in the manual for re-using the cam plate that includes inspection of the gasket on the back of the plate. If you go with a new plate, I would get one that is the same as the original and not use the newer tapered bolt design from GM that replaced it.
