PTV clearance on this LQ4/LS3 head setup
Gents,
I'm installing some LS3 heads in anticipation for my LSA blower install. The car will still be N/A for another 6 months or so
I've been running the Tick Torquemax Stage 2 cam which had plenty of clearance with the 243 heads. I called them and they said it "should" be fine with the LS3 heads
But I figured it was worth asking you guys for reassurance before I waste my time installing everything
SBE LQ4
LS9 headgasket (.051)
LS3 heads (not milled)
231/235 | .625"/.605" | LSA111+2
I've compared the cam to a bunch of other LS3 cams and it has less duration and lift than some. Thoughts?
Thanks
Mike
SBE LQ4
Thanks
Mike
LS1Tech Premium Sponsor
The 231 has ok ptv but the 109 is a tad close. id use an adj timing set, degree the cam, and set it up at 110-111. youd be surprised how far off the icl on that cam can be. its not ticks fault, it just happens.
That's what i would do. Option 2 is get adj set, retard 2* to 111 icl and run it. you dont need more advance with a blower anyway but youd prob like more lsa honestly.
Old School Heavy
Gents,
SBE LQ4
231/235 .625"/.605" LSA111+2
Thanks
Mike
SBE LQ4
Thanks
Mike
Also, with the dish pistons in an LQ4, you also get some additional valve clearance. I am not sure how much extra the dishes afford, but they do afford some additional.
