Dynamic compression
Old Jun 29, 2017 | 06:42 PM
Dalton Barrett's Avatar
Default Dynamic compression
can anyone help me figure the dynamic compression on my engine? The static compression is 12.4/1. The cam I'm using is a vrx5 236/238
Old Jun 29, 2017 | 07:47 PM
slogo's Avatar
http://www.wallaceracing.com/dynamic-cr.php
Old Jun 29, 2017 | 08:05 PM
Originally Posted by slogo
How do I find when the intake valve closes at bdc?
Old Jun 29, 2017 | 11:16 PM
Look up the event specs of your cam.
Old Jun 30, 2017 | 03:47 AM
Exidous's Avatar
It will all be listed on the cam card. It's impossible for anyone to calculate the DCR without knowing the duration, LSA and advance. The IVC is critical on calculating DCR.
With an SCR of 11.56 and a 225 intake, 114+3 cam I got something like 8.96DCR. Starting with higher SCR and a bigger cam is fine but you'll be in the 93OCT required range for sure unless you are running a really low LSA to bleed off the compression.
Old Jun 30, 2017 | 08:56 AM
okay, I got my cam specs and figured the intake closing point at 52. This leaves me with a 10.35:1 dynamic. This will be too much compression for pump gas won't it?
Old Jun 30, 2017 | 09:12 AM
speedtigger's Avatar
Old School Heavy
If your IVC is 52 ABDC @.050", then you need to add about 27 to that number. The dynamic calculators are designed to work on seat timing or timing at .006" for a hydraulic camshaft which is about 25-28 more depending on the lobe. So, in your case, use about 79 for your calculation.
Old Jun 30, 2017 | 04:44 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Use the wallace racing cam degree calculator to determine IVC ABDC if you don't already have that on your cam card. Use the advertised duration when typing in the duration figures.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Jun 30, 2017 | 06:02 PM
Old School Heavy
If you are using a computer, you can use the free Cam Motion Cam Timer download. It is a lot more versatile than web based apps as you can change any parameter and all of the others update to match. You can also have more than one up on the screen at a time so you can compare multiple scenarios. You can also use advertised duration or duration at .006" if you have those available. Download it free here:
http://www.cammotion.com/cam-timer.php
Old Jun 30, 2017 | 10:33 PM
Thanks! if that's right then it will be right at 8.35:1 and I should be good
Old Jun 30, 2017 | 10:34 PM
I'll download it now. Thanks!
Old Jul 2, 2017 | 08:37 PM
pantera_efi's Avatar
Default EAP Pro
Hi Dalton, I use EAP Pro from Performance Trends.
I do this for free, just send your details.
I ask the reason for your request ?
Lets agree it's about Knock Rating ?
There are some factors OFTEN NOT ASKED :
The Local Operation Altitude ?
The Rod Length vs Stroke ?
The Crank Shaft Target Wheel tooth count (24 or 59 ) ?
The Piston to Head Squish Distance ?
The Piston Pin Offset if any ?
The Normal Operational Coolant Temperature ?
The Camshaft Timing AS ASKED, I would use Split Overlap ?
(2.5/2.5)
Lance
