At A Loss With HP Dyno Numbers!!
We carry the fast36 which are actually 42lb at 58psi. they are $300 fit perfect and are easy to tune and idle perfect.
Stock truck intake and throttle body, stock MAF with an ebay intake/filter.
I dunno if that helps as a comparison.
Dyno in third vs second will bring the power up a bit and the torque down a bit, which would be more in line with what you'd expect to see.
I still see some features that look "off" on the dynographs, as mentioned before, and I just don't think that anything discussed explains it - unless it's the throttle not opening all the way or the CAI air inlet collapsing between filter and throttle.
For ***** and giggles, you might also try this... Remove valve covers. Manually rotate the engine to TDC for cylinder 1. Try to wiggle pushrods. if they wiggle, you have a collapsed lifter. Then, rotate the engine to the next cylinder TDC (#8) and check pushrods, then 7, then 2,6,5,4,3. You find a loose pushrod, there's the whole problem.
