At A Loss With HP Dyno Numbers!!
#81
Just so ya know, "I-pipe" is "Intermediate pipe" as in between Y-pipe and muffler
#82
There are a couple of adjustable connection points on the throttle cable linkage. I ended up making adjustments to remove the slack and that made the difference. There is also a TPS sensor on the side of the throttle that may need to be adjusted. A voltmeter is needed to confirm the voltage when fully opened and fully closed. There are write ups all over the forum on how to do this correctly. Your tuner can probably help check the voltage side of things.
#85
Hello 99cherrySS. I'll try to remember about checking the TPS. Hopefully the guy that did my upgrades back in December can get in touch with his friend to do some dyno pulls in the near future. 99 Black Bird, I did have Mike Norris retune my car since the LS6 instake and 243 heads were installed about a month ago. He has been extremely busy and I can usually only get to him on a Saturday by appointment only. And ddnspider...I did deal with the performance shop before that installed all of my upgrades back in December. Plus it seems that there aren't too many places that does performance work on Fbodies around Indy from what I've heard. I'm hoping to get some kind of answer or solution preferably to my low numbers.
