Ls1 restoration help?
Old Jul 20, 2017 | 01:29 AM
  #41
07NBSChevy's Avatar
Well I did say At Least, I didn't want to over estimate. I can see with the right cam he can come close to 500 at the crank.
What engine did you test your hot cam in? Was it pretty much stock? That would be some good numbers in a 5.3
Old Jul 20, 2017 | 01:32 AM
  #42
tech@WS6store's Avatar
LS1Tech Premium Sponsor
99ls1 853 heads ls6 intake speed eng long tubes tsp catback slp lid. m6 with 390s. made 385...prob room for more with a bit more tuning and cooler air but that's what it made.
Old Jul 20, 2017 | 02:39 AM
  #43
07NBSChevy's Avatar
I may have to look into this cam, it made some good power. What was the peak rpm for Hp/Tq?
Old Jul 20, 2017 | 08:09 AM
  #44
With that setup 6300 and roughly 4700-4800
Old Jul 20, 2017 | 02:47 PM
  #45
GLs1's Avatar
Default Harness and ECU
Oh I forgot to ask, I'm also going to need a harness. Probably like a plug and play one that's built with a good ECU for tuning.
Or should I just get another harness for the LM7 and splice it to the G35 harness?
Old Jul 20, 2017 | 02:56 PM
  #46
Emailed you info on harness.
Old Jul 20, 2017 | 04:02 PM
  #47
GLs1's Avatar
Thanks. So when I go in for a resurface and honing, what else should I get done there? Heads? Etc? And will they disassemble and reassemble for me?
Old Jul 20, 2017 | 04:05 PM
  #48
Any competent machine shop can do all of that.
Old Jul 20, 2017 | 04:08 PM
  #49
GLs1's Avatar
Great, so as long as I buy everything before I go in it should be fine? And how much do you think all of it would cost? (Disassemble/resurface/honing/rebore/assemble) anything else should I get while I'm there too?
Old Jul 20, 2017 | 04:23 PM
  #50
Ive quoted basically an entirely new engine inside. Nothing overlooked besides pickup tube.
It would be roughly $600-900 for disassembly, machine, install cam bearings, and assemble. Thats why my local shop would charge.
Old Jul 20, 2017 | 04:25 PM
  #51
GLs1's Avatar
Okay, so with all the new parts and everything done at the shop, it should cost around in total?
Old Jul 20, 2017 | 04:30 PM
  #52
That range would be $1300-1600 roughly. unless you need more machine work like rod hone or crank polishing.
Head work is sep but not expensive. Like others said a set of 243 heads would be the best to use. You can find em used on here from 400-600 for the pair, have em taken to machine shop and disassembled, clean, valve job, and reassemble with new seals and springs. OR we have new castings that would cost you 950 shipped already machined and assembled with springs for the pair.
Old Jul 20, 2017 | 04:33 PM
  #53
GLs1's Avatar
So $400-600 for new ones, and what would be the price for the machine shop? Would it be cheaper then just getting new ones? I guess it depends on how much I get the used ones
Old Jul 20, 2017 | 04:37 PM
  #54
Used 799 heads on here usually go for 400 to 600 for the pair. thats the normal going rate on fb and most local guys also.
Old Jul 20, 2017 | 04:39 PM
  #55
GLs1's Avatar
Okay, well thanks for all the help! I'll post again if I have any more questions
Old Jul 21, 2017 | 08:15 PM
  #56
07NBSChevy's Avatar
Ah, well he should know now. I have compiled a list of all LS production engines with block type.
This is all 1999-Current Production LS engines, Gen3 and Gen4.
--Gen3 LS engines--
LR4 4.8- Cast Iron Block
LM4 5.3- Aluminum Block
L33 5.3- Aluminum Block
LM7 5.3- Cast Iron Block
L59 5.3- Cast Iron Block
LS1 5.7- Aluminum Block
LS6 5.7- Aluminum Block
LQ4 6.0- Cast Iron Block, 1999/2000 Engines used Cast Iron Heads.
LQ9 6.0- Cast Iron Block
--Gen4 LS Engines--
LY2 4.8- Cast Iron Block
L20 4.8- Cast Iron Block
LMF 5.3- Cast Iron Block
LY5 5.3- Cast Iron Block
LMG 5.3- Cast Iron Block
LH6 5.3- Aluminum Block
LC9 5.3- Aluminum Block
LH8 5.3- Aluminum Block
LH9 5.3- Aluminum Block
LS4 5.3- Aluminum Block
LY6 6.0- Cast Iron Block
LS2 6.0- Aluminum Block
L76 6.0- Aluminum Block
L77 6.0- Aluminum Block
L98 6.0- Aluminum Block
LFA 6.0- Aluminum Block
LZ1 6.0- Aluminum Block
LS3 6.2- Aluminum Block
L92 6.2- Aluminum Block
L99 6.2- Aluminum Block
LS9 6.2- Aluminum Block
LSA 6.2- Aluminum Block
LS7 7.0- Aluminum Block
--All GenV EcoTec3 Engines Labeled "LT"--
LV3 4.3- Aluminum Block
L83 5.3- Aluminum Block
L8B 5.3- Aluminum Block
LT1 6.2- Aluminum Block
LT4 6.2- Aluminum Block
L86 6.2- Aluminum Block
Old Jul 21, 2017 | 08:49 PM
  #57
Wow! Thank you! That took a bit of research, and it looks comprehensive!
Old Jul 21, 2017 | 09:03 PM
  #58
07NBSChevy's Avatar
Ya its some good info. I made a list at my shop of all Engines (Gen2 LT, Gen3 LS, Gen4 LS, and Gen5 LT) that has the years and vehicles they were in (U.S. Only), power output between years, bore/stroke, heads used (Casting numbers), Block I.D Tags, RPM of peak power and torque, Max rpm, Block and Head Material and so on. Took me some time to find all the info
I need to make a List of all Gen1 Small/Big Blocks but there are so many different engines and different variations used in different vehicles that it will take a good amount of research.
Old Jul 21, 2017 | 09:26 PM
  #59
LOL Gen I stuff could fill a dictionary-sized book! Though I guess it could be done. GM did the biggest mix-and-match of parts ever with the good ol' smallblock! From the 283 and 327 came the 302 and 307 by swapping crankshafts(to oversimplify): A long-stroke smaller bore 307 for good low end for grocery getters and the short stroke bigger bore 302 to scream in the Z28. Genius! Interesting stuff for sure! Best to ya!
Old Jul 21, 2017 | 09:29 PM
  #60
07NBSChevy's Avatar
It will not be fun doing the research, one of these days I will get to it....whenever I have 16 hours to dedicate to it lol.
