Another 500hp ls1 build
My goal is to get it as close to 500 as possible
My current set up is
2002 ss
Ls1 -3.2 dish pistons, forged rods and stock crank
Tick sns 3 (235/243 111lsa) , stock 243s with btr 660s and trunnion upgrade , ls6 intake stock tb slp lid, 42lbs injectors, aeromotive 340lph with Hotwire kit, ls7 lifters, 1 7/8 long tubes off road y. All through a monster stage 3 and a mwc nine with 3.90s.
Was really hoping to at least break 400rwhp and only dynoed 379, could be a multiple of scenarios but just said screw it let's get this new build going
Picked the mms 220s mamofied
10mm upgrade with the yt rockers
Johnson lifters
Msd intake mamofied
Custom cam on the bigger side of things
And going true duals on the car as well
Let's see how this goes, work in progress but hopefully it's worth it
ATI dampener
Electric water pump
Light clutch
Also, consider the following options to get everything you can get out of it:
LLSR instead of hydraulic roller cam
Electric or manual steering
Crank scraper
Don't be afraid to spin it. Rpm is HP. You'll likely max out torque around 430-440. It's justball you're gonna get from a sbe 5.7. The higher in rpm she peaks, higher the HP number will go.
Good luck!! Enjoy the build and working with Tony
ATI dampener
Electric water pump
Light clutch
Crank scraper
* better valve control which will support more aggressive ramp rates and higher rpm.
* no pumping up and down delays
* higher oil pressure to the rest of the engine (I saw 13 psi gain at hot idle from 25-38)
The ONLY advantage to a hydraulic roller over solids is maintaining zero lash. After that, generating tq, revving, controlling valves, solids are better
ATI dampener
Electric water pump
Light clutch
Crank scraper
Yea ots gonna spin alright shooting for 7400
As of now I haven't spoken about a llsr setup but there's plenty of time to go ahead and get that going as well
2 for consideration, Carbon Fiber Driveshaft reduces weight &
NVH, acts like a dampener on the back of the Crank, really
Smoothes the high RPM spin, and R.E.M. Polishing the Ring &
Pinion, should be worth 6-8 RWHP, even more with a 9". I
hope to be Dyno Testing the delta by the end of August.
Also agree on the LLSR, worth 15+ RWHP even with equivalent
Specs adjusting for Lash, along with ability to go .030-.040 more
Lift everything else equal. Something like
237/243 .680"/.660" LLSR VS 231/237 .630/.610" HR
Spitballing here not giving a recommendation.
Working with Tony is a great decision as both
Darth & I can/will attest.
Good Luck!
2002 ss
Johnson lifters
Msd intake mamofied
Good Luck!
Seems low… i’m new here but i have a 1985 camaro with an LS1 swap from a 2001 camaro, replaced the fuel pump (upgraded, forgot the specs but it’s from summit, good for 500whp)
and a full hooker race exhaust, T56 transmission, and it got dyno’d at 340.2 whp @5200 rpm and 362.1 ft lbs torque at the wheel. looking to do a cam that won’t cause me much loss of low end torque. don’t know what cam to buy, or lifters/ rods/ anything else i might need.
