Cam thoughts w/ Milled 243s
Old Jul 31, 2017 | 06:32 PM
  #41
ddnspider's Avatar
Originally Posted by tech@WS6store
Left to be desired? He loves it. Not only vs his orig hot cam but vs others.
On any other project again no one would ask for all that info though if it were any other cam. It dynod low but ran great at track and his feedback is all him. most combos that dyno low are just accepted as dynoing low.
We have sold quite a few of these actually.
Your questions have mostly been answered in both his threads on it honestly.
Reading comprehension.....left to be desired about what he documented and information he provided or left out....like d/a temp etc. And if you think nobody would ask the same questions about gains for a cam swap if it were any other cam you're mistaken.....especially any other cam that is as pumped up as you and him try to make it be. Instead of letting the results speak for themselves you consistently make excuses for him about info that was left out.
Old Jul 31, 2017 | 07:28 PM
  #42
tech@WS6store's Avatar
LS1Tech Premium Sponsor
There is no need to ask the questions in other threads if you want the answers from him about it. Ask him or post in the thread. He doesnt follow along on every thread about it. Its our cam and his results.
I let the results speak for themselves then you come along and ask for more da tune etc as you said. alot of that was answered in his thread on the track and his thread on the cam itself.
What is the real issue? I shouldnt be excited about a new cam we came out with? I shouldnt defend it? I shouldnt want it to succeed? What is the issue?
Garbling this thread up more really doenst help any of that either.
Old Jul 31, 2017 | 07:45 PM
  #43
ddnspider's Avatar
I asked 1 question and then you muddy the water and make excuses about why d/a doesn't matter. Maybe let the owner do the talking in his own threads like most other vendors on here do instead of speaking for him and only information that helps your cause....like it gained 5mph but ignore the back to back Dyno graph. I wouldn't let you cam my lawn mower....and I don't even own one.
Old Jul 31, 2017 | 07:51 PM
  #44
Ok. You are entitled to your opinion.
Old Jul 31, 2017 | 09:11 PM
  #45
wph351's Avatar
Originally Posted by CAMMOTION PERF
Yes, the Titan 4 will clear with .030" milled off of the heads and it is a great street cam with excellent mid-range power, a nice sounding idle and very good drivability. It is available in 5150 Steel Alloy for $399.00.
You can read more about it here:
http://store.cammotion.com/the-titan4
Would it also clear 243's milled .025 running. 040 cometics? Want kind of power increase over a 224/224 112 .600/.600 ?
Old Aug 1, 2017 | 02:34 AM
  #46
jaywill's Avatar
Not hi Jack but how does the 224/224 work in your combo ?
Old Aug 1, 2017 | 05:24 AM
  #47
wph351's Avatar
It runs well. Made 390/365 ish. Whent 11.77@112. Gets flat up top but midrange is to my liking.
Old Aug 1, 2017 | 11:29 AM
  #48
CAMMOTION PERF's Avatar
LS1Tech Sponsor
Will it clear? Yes it should, but it is getting a bit tighter on piston-to-valve clearance than I typically recommend. Also, with anything that has been modified, you should carefully check piston-to-valve clearance with a new cam before running the engine.
As for power increases, More likely 5-10 hp than 10-15. For me, it would not be worth the time, money and effort for that small of a change.
Old Aug 1, 2017 | 07:58 PM
  #49
z28ss4me's Avatar
So what do you think would be better in my case? Keep my TR224 (224/224 56x/56x 114) and run .040 Cometic for better quench and CR
OR
Run the GM MLS .051 and the Titan 4?
Again, the goal being power under the curve for road course duty.
Old Aug 1, 2017 | 08:02 PM
  #50
You would want to measure your deck clearance first before getting gaskets. Guessing at a .040 thick and less than .010 ptd isnt a good idea.
