5.3 to 5.7
Old Aug 21, 2017 | 09:36 PM
88stanger's Avatar
Default 5.3 to 5.7
So please bare with me on this. I am new to the LS family
I have a 2000 4.8/5.3 block with 862 heads. I plan to buy a complete build kit from WS6Store to include the hot cam kit. Here is my question. I was thinking about boring it out to 5.7, but if i do that what needs to be changed, besides the pistons, cam is planned to be changed. I am specifically wondering about the injectors, throttle body, got to send the brain in to get flashed anyways, so i would make sure the engine data is given to them.
Any help with what must be changed is appreciated.
PS i have done a few searches on this and could not find the data.
Old Aug 21, 2017 | 09:43 PM
Spamfritter's Avatar
The 5.3 and 5.7 engines pretty much share all the same parts. Injectors, intake, throttle body and almost everything else will transfer over just fine.
Old Aug 21, 2017 | 09:46 PM
88stanger's Avatar
Thanks for the input. I should note that my motor is currently a 4.8, but i found a correct 5.3 crank 12552216 and a set of full floating rods. I was able to find the injectors are the same from 4.8 to 5.3 but not sure about the throttle body.
Old Aug 21, 2017 | 11:08 PM
LS1MCSS's Avatar
The pistons will be heavier than what the engine was originally balanced with, so you will need to have it balanced before assembly.
Old Aug 22, 2017 | 12:10 AM
88stanger's Avatar
Great point, was not thinking about balancing. Hmm, not sure it's worth the cost to go from 5.3 to 5.7. Maybe if bore is required, but still balancing will be a bit.
