Johnson 2116LSR and pushrod lengths
Noted each length, ordered Manton PR's and had them add .035 to each of my numbers. Verified each PR and my caliper is within .002 . I ended up getting 5 different lengths to get me to the .035 .
Checked the final preload on the new PR's with a dial indicator and I end up with .051
This sucks due to its out of the recommended tolerance. I did have to modify my checker to make it shorter. Made the ball end myself but I think it must not be shaped perfectly. So my baseline measurements were wrong. Looks like I need to get a new length checker. I called Trevor Manton he said that they can shorten these new pushrods for me. Sooo, I am going to check every valve with the new pushrods and get a perfect measurement.
On another note, I did start the engine before checking the pushods. And its was a sewing machine which made me think they were actually going to be short. I was surprised to see them be too long.
The worst of this issue is that I was going to try and race the redemption 9.0 this weekend.
On a side not for people that use the bolt turn method to check lengths, which I did when i first built the engine. I didn't have a dial indicator that would fit right at the time. I can get the bolt torqued and have about .020 to .030 preload, but the plunger slowly keeps dropping down and I end up with about .020 more of preload. And you do not see this happen with the naked eye. So you can easily get too much preload doing the bolt turn method and not know it.
Best bet for you would be to directly measure preload with a dial indicator since you have known pushrod lengths. Then subtract the amount over and get a final value.
So its back together and work on the tuning this weekend. Then redemption 9.0 next weekend with fingers crossed. Due to the Hurricane hitting this weekend and we are expecting up to 3ft of rain I wont get to do any real testing.
