oil plug valve( barrel valve) removal ??
Have the transmission out and was told it would be a good idea to change the oil restrictor / oil barrel valve. I don't see anyplace to get a tool on the valve and I ,m concerned that it maybe brittle after 18 years. Don't want to crack it in there...... Any helpful ideas are appreciated
Thanks
BobH
Thanks
BobH
Are you talking about the galley barbell? There is a allen plug directly above the right side of the oil filter housing (I forget what size) pull that plug out after you have removed the rear cover on the engine. You can stick a screwdriver in that hole and pry against the galley barbell and pop it out of its hole.
Thanks,
BobH
