5.3 build- boring and compression ratio input
So, now this effects my planned build. I was going to do: stock 5.3 bore block, 4.8 pistons, 799 heads milled down .030 to achieve 10.5:1 compression. I was also going to run a TSP 224r 112 Lsa cam.
The machine shop is wanting around $250 to bore it and I've found a brand spanking new 5.3 block off Sunmitracing for $350. Should I just buy a new stock block and carry on with my build as planned?
OR since I need to bore my current block over should I just go ahead and bore it out to a 5.7? If I do that I'll need a new cam choice I suppose along with the obvious balancing of the rotating assembly.
My 799 heads have not been milled down yet, but would boring the block out affect my compression ratio? It's not effecting the combustion chamber much so I wouldn't think it would, but I'm not sure.
Any input is helpful, I'm kind of leaning towards just carrying out my build as initially planned since it sounds a little cheaper to me.
If you want to use LS1 pistons, your machinist would have to bore and hone the block, which is going to be more expensive. You might be able to find some used pistons in the classifieds, but you'll be taking a chance since they would all be 10+ years old. Again, you could probably get hypereutectic pistons as well. This option would make significantly more power than a 5.3 due to the larger displacement and bore size. It's more expensive, but there's more reward.
The early has TWO long head bolt sizes = NOT OK
The early has a 1" HOLE between the Main/Cam bulkheads = NOT OK
The early has NO provision for the Chain Guide = NOT OK
ANSWER these questions FIRST.
The GEN-IV AL is fine with THICK WALLS and MUCH Stronger.
The next step before a "bore" is to Sonic AFTER RINGS ARE FOUND.
YOUR shop 3.78+.010 ???? RINGS ??????
Total Seal 3.78+.005 OK
Lance
Will punching it out to take 5.7 pistons affect my compression ratio? As stated before I already have a set of 799 heads that I was going to have milled down to get my goal of 10.5:1 compression.
I already know I'll need to get the rotating assembly balanced.
Would my cam choices open up to the same choices the LS1 guys have? I seem pretty limited right now with the 5.3, that's why I was going to do a 224R
http://www.wallaceracing.com/cr_test2.php
You could use more duration and overlap since you will have more displacement and you won't have to mill as much to achieve your desired compression ratio so you'll gain PTV. You will be able to better unshroud the valves with the larger bore as well.
If I bore my 5.3 to a 5.7 and run stock 799/243's then essentially I'll have an Iron LS6 that would be at 10.5:1 compression.
Then I'd pop a 228R cam in and be all set.
Sounds simple enough.
I'm just going to stick with what I got. Bore it out 3mm over and put LS1 pistons in it, balance the rotating assembly, run the 799 heads without milling them and I'll be at my goal of 10.5:1 cr. Then I think I'm going to do the TSP 228R cam
If its going into a truck, dont do the 228r. use something smaller. unless you get it cheap. std pattern cams arent as well performing as splits.
Using the 228r in a truck isnt very good unless you supplement the bottom end with 373+ gears and a 3k+ stall.
A smaller and split cam would fit you better. id look at the 223 226 tsp stg4 truck cam
I'll basically be building an iron LS6, just curious as to why I'd have to run such a small cam?
