I was wondering if you could shed some light on something I just noticed today. I have 3 old core LS engines sitting at my shop. One of them is a 4.8L
engine that we pulled out of my sons truck as we upgraded to a 5.3L
engine. His old 4.8 had 274K miles on it when we pulled it. No issues with it at all except it was burning through a quart of oil every 1000-1500 miles. Noticeable blue smoke on first start up in the morning. Today I pulled both valve covers and immediately I noticed something was off. The drivers side of the engine looks like it was being starved for oil. The rockers on that side are DISGUSTING with tons of baked on carbon, and crystalized oil deposits. Even the pushrods, and the heads themselves where the pushrods come up through them look like it is discolored from over-heating, or just baked on oil. The passengers side=looks brand new! There is NO carbon build up on any of the valve train components on the passenger side of the engine. I pulled a rocker, and then a pushrod and ran it through my fingers and there is NO build up of any kind on ANYTHING on the passenger side of the engine. If I took a picture of both sides of the
engine you would think I was pulling a prank. It does not seem possible that one side of the engine could look so bad, and the other side so clean. All 8 rockers on the drivers side (bad side) are DESTROYED where the push rod rides in the cup. The cups are wallowed out and the oil feed hole is starting to get damaged by the push rod tip.
What in the world could explain the drivers side of the motor being starved for oil?????????
I have a 2nd 5.3L core engine here and I pulled the valve covers off of it and find THE EXACT SAME THING! What can I do to insure that my 6.0L build gets the oil that it needs to the drivers side of the head to prevent this? Has anyone else noticed this before? It worries me that there is such a stark contrast between the two banks of the engine. I thought the oil was fed up through the push rods to the valve train on top of the head. What could explain 1 side of the engine starving for oil, and the other side looking like a brand new engine?
