My quest for a stock bottom, 450hp LS1
#41
Moderator
Received 1,838 Likes
OP, this is probably a "pick your poison" kind of thing. I'll say this -- adding a blower to a stock engine is easier than a heads/cam install. Hell, you could do a remote turbo in the back of the car and hit your 450 goal. There are also tons of LSA conversion kits now for the cathedral engines. Even kits for truck engines.
But, at similar power, for example two engines at 500 HP, I'll take NA over boost. But if it's 500 NA vs 700 boost, I'll take boost.
From your original post, I assumed you wanted NA, and for the most part, boost will get you far above that level anyway. but if you're only going to boost up to 450, I'd tell you to stay NA.
Again, personal preference / pick your poison.
#42
#43
#44
LS1Tech Premium Sponsor
Most supercharged systems really need a fuel pump also that isnt included in the kits. Some use doff fmu also tho. Some come with inj some do not.
Cost comparison isnt even a comparison as cam only is obviously way less expensive, even if adding in other inj or fuel pump.
Thats talking brand new kits like a p1sc procharger vs a cam kit. Not used or pieced together etc.
Both have their place but arent really interchangeable aa far as goals for alot of people. Ther is a huge reason most do heads cam vs a supercharger and with quite a few customers its sound. They want to sound like they make power. Crazy but true. Plus cost.
#45
Moderator
The procharger one I drove felt similar to a turbo, where it didn't have much in the off idle range, but kicked in hard around 3500 rpm. it definitely carried better. but for DD, I felt like it wouldn't have the fun factor without revving it.
Lastly, streetracing, a guy with 535 HP camaro on a turbo wanted to run me, and I beat him handily - and I mean waiting at 5000 rpm in third for him to catch up and hitting it again while he was coming up on me and I still pulled him. We stopped and talked afterward. He said he had never got dragged like that by another LS car.
Is it possible all three were not optimally set up? yes it is, but I'll never know that for sure.
#46
Moderator
That's very true. You see the threads where people ask how to tune their car to sound cammed or they want to spec a cam for "lope". I don't get it. Most of us cammed guys spend our efforts taming the cam. I'll admit it, cammed cars sound pretty cool, but you can just give yourself a vacuum leak to get it to lope at idle also for far cheaper...
#47
In reality most overcam though. If there is a stg 1 - 5 then dammit they want stg 5. i dont get it, but youll soon see em selling the brand new cam "less than 1k miles etc of 5 dyno passes". Ive seen it alot. Hard to steer a customer the right way when they are already leaning a certain way.
#48
Moderator
It's almost better to tell someone how you plan to use the car and how much BS your willing to deal with and let them spec the cam accordingly, unless you really know what you're doing.
#49
Well, the blower type I drove had tons of torque, especially right off idle, but power fell off really fast after crossing 6000 RPM. I've always been interested in putting a blower on my suburban engine for that low end grunt. So, yeah, I guess I wouldn't have to shift as high RPM to hit a power number, but the car didn't feel faster to me.
#51
Hell if you wanted to boost it, I'd sell a complete and brand new Huron truck kit for about a grand more than the TSP heads and cam kit you were talking about. Forced induction doesn't have to be expensive to get into unless you do like I and most everyone else do and overbuy in the hopes you will grow into it later. If you stay grounded, simple parts go a long way. And a turbo stock motor at 450-550whp will drive better than any heads and cam car ever will at the same power level.
