Oil priming question
Old Sep 8, 2017 | 07:48 PM
moekluse's Avatar
Default Oil priming question
Hi everyone, im about to crank up my ls6 and I was priming the motor through the plug into the pump and I waited till all rockers had oil coming out of them bit these two rockers weren't spitting out any oil. I didn't crank yet but I did turn over and my mechanical gauge is reading 30 psi while cranking. Is this just a matter of oil needing to find it's way? I used Joe Gibbs assembly lube on everything. Thanks
Old Sep 8, 2017 | 08:06 PM
slogo's Avatar
Im sure you cleaned pushrods before installed. I have looked down mine after setting in the garage for awhile and they was full of crap.
Old Sep 8, 2017 | 08:17 PM
moekluse's Avatar
they are new hardened trickflow pushrods, I did take a long thin piece of steel and poke through the assembly lube in the pushed. Motor was sealed so nothing would of gotten in there.
Old Sep 8, 2017 | 08:26 PM
slogo's Avatar
Well hopefully it is just full of Assembly lube and just needs a little more oil to push through.
I couldn't sleep till I looked down them myself.
Old Sep 8, 2017 | 08:30 PM
moekluse's Avatar
Is 30 psi enough?
Old Sep 8, 2017 | 08:37 PM
slogo's Avatar
Sorry I cannot give an experienced answer there, wish I could. But I would solve the problem
before I found out the hard way, a little work now may be cheaper than a lot of work later.
