King bearings, XP or SI
Old Sep 10, 2017 | 02:29 AM
98 4mula's Avatar
Default King bearings, XP or SI
I was looking at ordering some rod/main King bearings and was looking into the XP series and SI. Is XP mostly for forged cranks? I have a stock crank in my LQ4 that will have around 420-440 rwhp (Heads, cam). Will I be better off with the SI series? This will be a weekend cruiser. Thanks
Old Sep 10, 2017 | 11:10 AM
pantera_efi's Avatar
Default King Bearing Tech
Hi 98, good tech question, I use both, the SI for the mains AND the XP for the rods in your case.
You will find BETTER .002" clearance with the AL main bearings + long life.
You will find BETTER .003" clearance with the Tri-metal rod bearings + long life.
I sell both
Lance
Old Sep 10, 2017 | 11:18 AM
madsv1000's Avatar
I'm interested in how they hold up. I've only ever used clevite and the same with the shop I work at. Only reason I've went with clevite is that I've seen them go for 24 at Le Mans, and not really show much wear.
Old Sep 10, 2017 | 04:43 PM
98 4mula's Avatar
What about the HP rod bearings, what are your thoughts on those. You wouldn't recommend XP for the mains in a stock crank?
Old Sep 10, 2017 | 08:34 PM
Cwarta's Avatar
I personally run king bearings exclusively. I only run hp or xp, typically xp. We run 50+ pounds of boost on our BBC pullin tractors, had issues with flaking with clevites, went to king and the problem went away.
Basically the SI is a oem equivalent replacement as I understand it, the hp/xp are better.
