PRC CNC'd Heads
Old Sep 14, 2017 | 07:30 PM
jodyjo's Avatar
Default PRC CNC'd Heads
Hi everyone. I have a question about a used set of heads that I bought. These are a set of CNC ported 799's by PRC. Is it common that only the top parts of the intake runners to be ported? It seems like the bottom halves are uneven and below some sort of "plane" as to where the rough castings did not get CNC'd. Thanks!
Jody
Attached Thumbnails PRC CNC'd Heads-image2-1-.jpg   PRC CNC'd Heads-image3.jpg   PRC CNC'd Heads-image1.jpg
Old Sep 14, 2017 | 08:25 PM
True. Flow is mostly affected by the upper half of the port; which is why the floor of the port is usually not touched, as lowering the floor is actually detrimental to flow.
Old Sep 15, 2017 | 11:00 AM
ironmanLS1's Avatar
I seen something similar when I had 799 heads ported by TEA. Some of the casting wasn't completely cleaned up and it will probably vary slightly from casting to casting.
Old Sep 16, 2017 | 08:17 AM
cookseyb's Avatar
If it bothers you get a "Tootsie Roll" die grinder and polish them up...
Old Sep 16, 2017 | 08:53 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
There are too many irregularities in the casting process. CNCing heads gives you a repeatable flow from port to port - sometimes raw parts of the casting are left behind because they are inside/outside the CNC program.
In short, it doesn't matter.
Old Sep 18, 2017 | 11:10 PM
wannafbody's Avatar
My PRC exhaust ports were only partially ported. The heads work great.
Old Sep 18, 2017 | 11:14 PM
Basically, material is removed ONLY where it needs removing. Makes sense to me!
Old Sep 19, 2017 | 12:04 AM
98CayenneT/A's Avatar
