Input on which direction I should go on LS chevelle build
I would do the 4l80. It’s a heavy bastard (200+lbs) but you’ll never have to worry about it. Our floors are the same and it didn’t take much massaging to the tunnel to get it to fit. Too bad you’re not local, I can get them mildly built to handle 800hp or so for $1100. I’d go with a yank or circle d converter. I’m running a pas3400. Good converters aren’t cheap though, might want to cruise the classifieds for a used one.
Love the Chevelle, looks like my color.
Very easy swap. Kept GM ECU and harness. Removed vehicle theft, cats and new axle ratio. Hooker cast iron manifolds fit A body great. Holley 302-2 oil pan fits perfect. The usual aluminum motor mount adapter plates. Modified rear trans mount slightly by lowering perch 1 inch for just a bit more tunnel clearance.
The car is so fun to drive now, whether idling around in town or cruising at 80 mph with great fuel economy to boot.
If you want more power, a single turbo setup is easy to add. For example my 70 Nova went easy 10.90's with a bone stock LQ4 on 7.5 psi with no intercooler and pump gas.
I decided 3 years ago to convert both cars from BBC carb/dist to junkyard LS EFI. Totally happy with the driveability and performance of both cars. And if you break the LS bad, it is just the price of your time and another junkyard motor for cheap.
We just changed out a truck accessory drive, in a 72 Chevelle, for that exact reason.
Aprox $1200. 2004 Vette drive.
Problem is the truck alt doesn't fit.
If that model Chevelle is ft steer, the p/s will/can cause issues.
I am using complete truck setup right back to and including the MF sensor where I have a conical Edelbrock air filter that sits right behind the battery.
The alternator and power steering are in stock position as per truck accessory drive.
Power steering pulley is smaller diameter from an 80's S10 with V6 to just clear the steering box. Alternator fits under stock hood. Even the "Vortec" plastic lid on top of the truck manifold just fits under the hood.
Stock radiator with truck fan and water pump.
Temperature cycles 200-204 degrees idling in stop and go traffic on a hot day with stock thermostat. No electric fans required.
