[VR] MAST 3.900 LS3 Heads/FAST 102/Kaotik Cam Picks Up 110rwhp On 383 LS1!
Obviously, the Mast Small Bore LS3 heads are excellent and work very well with the Fast 102 LS3 LSXR & VR Kaotic cam.
I wonder how well a Radius Rod LS3 intake which flows much better than a stock LS3 intake would work with the Mast Small Bore LS3 heads & VR Kaotic cam.
The lack of low end torque people complain about is usually at part throttle driving around town where big *** ports with big *** valves on small bores (4" for example) can feel lazy. I don't think anyone complained that square ports don't make torque down low at WOT.
Second, those MAST LS3 small port small bore heads are not even on the same planet as a stock port stock valve LS3 head. Slap on a stock LS3 head on that bitch and you ain't getting anywhere near the torque seen in this dyno graph.
But keep spewing your agenda
Kick *** results! That thing should flat move out.
