Cam advice
Old Oct 5, 2017 | 08:09 AM
Antc26's Avatar
Default Cam advice
I was looking for some advice or opinions on a camshaft for my 2002 Camaro ss. It's is m6 has 1-7/8 lt, slp exhaust and lid. I was looking at btr stage 3 and tick performance sns torquemax stage 3. Car is a street car with possible occasional track time. Usually just driven on the weekend. Want something with a pretty choppy idle to. Plan on keeping stock heads at least for now. If there's any other recommendations feel free to say. Thank you
Old Oct 5, 2017 | 08:24 AM
HCI2000SS's Avatar
Plan on keeping the stock 3.42's?
Old Oct 5, 2017 | 09:14 AM
Antc26's Avatar
Yes I do
Old Oct 5, 2017 | 09:36 AM
HCI2000SS's Avatar
Both those cams are a little on the bigger side for your particular setup, but with a good tune they should drive pretty decent. Definitely will have the chop that you're looking for
Old Oct 8, 2017 | 03:20 PM
Antc26's Avatar
Default w
any opinion on which cam is better to go with?
Old Oct 8, 2017 | 07:00 PM
HCI2000SS's Avatar
Last I remember the SNS 3 cam was a little bigger, so its going to be a tad more roudy. Between these 2 cams I like the SNS 3. That's just my personal opinion
Old Oct 9, 2017 | 09:05 AM
KILLERARMY's Avatar
Give Steven Balusik a call at Cam Motion about a camshaft advice.
Old Oct 9, 2017 | 03:17 PM
99 Black Bird T/A's Avatar
Regarding the SNS Stage 3, I would do 4.10's with this cam since on Tick's website bucking at 10 mph is mentioned and bucking at 1800 rpm is mentioned with 3.42's
Good gears like 4.10's or at least 3.73's makes six speed cars more fun in just about all circumstances...and easier to drive.
Old Oct 9, 2017 | 04:55 PM
Antc26's Avatar
yeah I was reading that on there site. Want to do gears just kind of on a budget slowly doing things
Old Oct 9, 2017 | 06:14 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Our high lift asa cam would be an option thats easier to drive with 3.42s but plenty of chop also!
As well as mid range and top end power.
Check out this thread
https://ls1tech.com/forums/generation-iii-internal-engine/1881622-first-start-ws6store-s-high-lift-asa-cam.html
Definitely a good budget cam at $515 for cam.and springs and reuse your stock pushrods!
Old Oct 9, 2017 | 06:41 PM
Antc26's Avatar
thank you I will definitely check it out
Old Oct 9, 2017 | 07:21 PM
I understand. Long ago in 2002 when doing HCI ( TEA heads, 224 /224 XE-R cam & LS6 intake) for my 99 TA the idea of another $600 to get gears and get them installed - sucked. Turned out the 4.10 gears were one of the best mods the TA ever got, made the car better in about every way. Some times it takes a while to get all the mods done. Took me 3 years to save up to do HCI in 2002.
Old Oct 9, 2017 | 07:37 PM
Ive actually had a recent customer go from 4.10s to 3.73s. He missed being able to use 1st gear lol. Running a custom 227/234 cam and the 4.10s took all the fun in the mid range away. He said he love it now.
Just .02 from another customer
Old Oct 10, 2017 | 03:22 AM
Antc26's Avatar
i would like to do gears to. I guess I coils just wait a little longer and save for them as well. I hear all good things about 4.10s
Old Oct 10, 2017 | 07:13 AM
David@Vengeance's Avatar
We have had excellent luck in combinations similar to yours with our VRX5 camshaft. This is a 236/238 .601/.605 113+2 and will offer the lope at idle that you're looking for while still retaining good driveability on stock gears with a solid tune. We also offer a cam/spring/pushrod combination with our Budget Cam Kit, as well as our Cam Kit Plus if you're looking to upgrade the timing chain, oil pump, and other recommended items while you're there. Check out the links below and feel free to reach out if you have any questions!
https://vengeanceracing.net/vengeanc...8-602-605.html
https://vengeanceracing.net/vengeanc...t-cam-kit.html
https://vengeanceracing.net/vengeanc...-kit-plus.html
Old Oct 10, 2017 | 07:31 AM
Antc26's Avatar
https://www.youtube.com/watch?v=gOHdXw27XAM
cool thank u!!
Old Oct 10, 2017 | 08:29 AM
Antc26's Avatar
cool thank u!!
Do you have any dyno sheets
