E85 and plug temps
Old Oct 11, 2017 | 04:02 PM
nine8ss's Avatar
Default E85 and plug temps
Hey all,
What kind of effect does E85 have on plug temp ranges? Every time I check my plugs (TR55s @.050), they are nearly immaculate and look brand new making it difficult to judge if they are the right temp. I occasionally get knock sensor codes and am trying to rule everything out.
Old Oct 11, 2017 | 04:23 PM
pdxmotorhead's Avatar
Anecdotal ,, I converted a Dwarf car with a Air cooled 1200 GSZr motor in it from race gas to methanol, it dropped the head temps on a 1/8 oval run from about 500+ to 238, cooled it enough I had to start pre-heating the oil to get the motor to come up to full temp..
Ethanol isn't quite as radical,, but its significant, the nascar engine guys got a huge power win in tuning once they got injection to go with the alcohol..
Old Oct 16, 2017 | 02:58 AM
07NBSChevy's Avatar
Compression Ratio will also play a factor in plug heat ranges as well, with or without using E85.
Old Oct 16, 2017 | 05:03 AM
SlasherVRGR's Avatar
Seems as though not to many people realize this. I started running tr6s NA because I have more compression than stock, and my car seems to love them.
Old Oct 16, 2017 | 10:58 AM
nine8ss's Avatar
Thanks for all the info. I am at 11.5:1 so I think TR6 will be in the near future.
Old Oct 19, 2017 | 07:17 PM
Old Geezer's Avatar
Default You should be
Originally Posted by nine8ss
Hey all,
be getting plug coloring w/ E85.
If they are looking "new" and the knok sensors are active, it may well be you are running very lean.What is the AFR?
Old Oct 20, 2017 | 11:23 AM
pantera_efi's Avatar
Default E SP Reading
Hi 98ss, YES and I agree with your report, a "hard read".
Send a quality picture, I can read the steel.
Your Knock sensors should be working correctly.
AS for "Old Geezer" tech, LEAN is ABOVE 1.00 Lambda/Rich is BELOW that value.
Lance
Old Oct 20, 2017 | 04:34 PM
nine8ss's Avatar
Commanded AFR is 10.09
Bottom plug has 500 miles, top two are from old build.
Trims are +/- 2%
Old Oct 22, 2017 | 11:28 AM
.boB's Avatar
With todays fuels and oils, it's very difficult to tune an engine by reading the plugs. If you're drag racing, you need to put in new plugs, shut down the engine at the end of the track, and then get towed back to the pits. That's the only way to get a clear reading.
One of the big advantages to alcohol is that it burns very clean. Chambers, valves, etc, all stay very clean. What you're seeing on the plugs is very normal for alcohol. You need a data logger to make sure your tune is correct.
