Which head gasket bore for 408 build??
Old Oct 14, 2017 | 05:05 PM
Chaset80's Avatar
Default Which head gasket bore for 408 build??
I’m building a 408 with a lq4 block and 821 heads. What head gasket bore would be the best to go with? I’m guessing bigger than 4.065 because of the size of the LS3 chambers? Should 4.08 work? I’m a noob when it comes to head gaskets for custom builds. 4.030 bore, but my heads are off of an engine with a 4.065 bore. Any help or recommendations appreciated, folks! Engine will be naturally aspirated and sprayed a moderate shot.
Old Oct 16, 2017 | 09:41 AM
KCS's Avatar
KCS
Moderator
The OEM 6.0L gaskets are 4.050" and are used with LS3/L92 heads all the time. I would prefer a little larger, like the OEM 6.0/6.2L gaskets which are 4.100".
Old Oct 16, 2017 | 03:56 PM
MuhThugga's Avatar
I would use the 6.2 gaskets. You want to match the gasket bore to either the chamber or the engine bore, whichever is larger.
Old Oct 16, 2017 | 04:13 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Youll need the 12610046 ls3 head gasket.
The gm 6.0s with rect port heads use the ls3 head gaskets also. Like the l76 in the G8 GTs. Same with ly6 etc.
