oil starvation issue on lm7
Old Oct 19, 2017 | 05:06 PM
chejos13ls1's Avatar
Default oil starvation issue on lm7
Hello, i have an 05 lm7 swapped into a 93 300zx with a turbo in the car. At first i just installed the stock engine into the car to see what i'll do, ended up with a spun bearing after a couple of weeks of beating the car. I figured it happened because of the unknown milleage of the engine plus the stress from the turbo. So based on that, i did new clevite bearings, new meilling pump and not so new but std size crank. So i did about a week of tunning/testing at about 8 psi and i just heard a bearing again. Is there anything that im missing on this set up for a propper lubrication? I always have at least a quarter of extra oil in the pan and the return for the turbo is on the front timing cover if it matters. Thanks
Old Oct 19, 2017 | 06:20 PM
It bears repeating- Was the oil pump pickup O-ring properly installed?
ALSO all gallery plugs in the block?
Old Oct 19, 2017 | 06:32 PM
I'm going to do the disassembly on the weekend, i want to know what to look for. I'll get some pictures.
Old Oct 19, 2017 | 06:39 PM
Yeah if you had 8psi max, there IS a problem. Likely something I mentioned above, would be surprised if different. BUT you never really know until you KNOW.
Old Oct 19, 2017 | 06:56 PM
Old Geezer's Avatar
Default ??
I think the 8 psi may be reference to boost?
I am wondering what the oil psi was, before the last failure.
Old Oct 19, 2017 | 09:21 PM
On second thought, you are probably right! Had the blinders on....
But yeah, a note about where the OIL pressure was would have been nice.
Old Oct 19, 2017 | 09:55 PM
Yeah im talking about the turbo psi, my oil pressure was right at 40 on start up and about 65-70 on light cruising. As far as i know that about average for a gen 3 engine.
Old Oct 19, 2017 | 10:58 PM
Your oil pressure is good! Did you check all the clearances or put it all together and figured it would be right?
Old Oct 20, 2017 | 09:14 AM
I had a local machine shop do the short block and i just did the top end. im going to open it up in saturday to see what's up.
Old Oct 21, 2017 | 07:10 AM
Old Geezer's Avatar
" right at 40 on start up and about 65-70 on light cruising. As far as i know that about average for a gen 3 engine. "
Not close, unless the system has been modified.
Old Oct 22, 2017 | 09:57 PM
when you say not close, do you mean that it should be higher or lower?
Old Oct 23, 2017 | 08:32 AM
moekluse's Avatar
those pressures sound very good. My newly rebuilt ls6 with a SLP ported pump runs about 49 psi idle
Old Oct 24, 2017 | 09:20 AM
RockinWs6's Avatar
Who put the bottom end together? What were the clearances? Was everything checked with mics? A lot of people use plastic gauge then wonder why the bottom spins a bearing.
Old Oct 24, 2017 | 12:30 PM
BlwnLs1GTO's Avatar
This raises a flag for me. What do you mean by this? Was it machined at all? Polished or anything? I'm curious if it's the same cylinder that spun. A spun bearing can ruin your main caps and bore. Did he check this or line hone the bottom end?
Old Oct 25, 2017 | 10:37 AM
Thanks for your input; the crank was just polished by the machine shop that build the short block.
