Heads, rocker, and fuel selection
I have been looking at the PRC LS6 stage 2.5 heads from TSP, are there any suggestions that would keep my in the same price range or should I just pull the trigger on these? I will be pulling off my current springs, and if they don't appear damaged, swap them to the new heads.
My tuner informed me that the factory injectors were running at 97% duty cycle with the mods already installed. I was looking at the Bosch 36lb/hr injectors, but would these supply enough fuel for the new setup? Also, at what point should I start looking at upgrading the rest of the fuel system?
Lastly, I have came across the Straub bushing kit for rockers. Would these be a better or worse choice over the comp cams trunnion upgrade?
Current mods: 224r TSP cam (224/224 int/exh dur, .600/.600 int exh lift), ls6 intake, slp lid, double valvesprings, ported tb, LT's, true dual, melling oil pump. Currently running 386rwhp/382rwtq.
The Straub kit is far superior to the Comp kit, as bushings are proving far better than rollers. Do a search here for threads on this. Don't just take my word for it. LOL
The Bosch 36 lb. injectors will be plenty for ya. That's what I run on the setup in my sig.
Here is a picture of my comp trunnions after 1,000 mi.
