How bad did I mess up?
Old Oct 26, 2017 | 09:07 PM
omc8's Avatar
Originally Posted by SheepDog209
I was planning to start with the #1 bolt and put it in to the torque spec (1st step) then do the same for #2 and so on. After they were all replaced and torqued to 22lbs, then continue with the degree specs.
If that's incorrect, please let me know.
Which long bolt in the sequence did you stretch ?
Old Oct 26, 2017 | 11:15 PM
SheepDog209's Avatar
I think it was #3 or 6 them the 2 short ones
Old Oct 26, 2017 | 11:47 PM
CattleAc's Avatar
Originally Posted by Suncc49
I would send it if it was my personal ride.... based on what sloppy and some folks are doing re using bolts and such....
If it is going to keep you awake at night re do it
Originally Posted by MuhThugga
Just run the motor. You'll be fine.
Most people torque the angles by drawing a dot at the 12 o'clock position on the bolt head. It ain't exactly a precise science.
I think if it was mine...I'd send it.
*But, if you don't...definitely go ARP.
Old Oct 27, 2017 | 09:23 AM
omc8's Avatar
If its #6 your golden, start there and work your way out.
Old Oct 30, 2017 | 10:55 PM
It was the 3rd bolt in the torque sequence, or the 2nd upper bolt in from the end. I started with the 1st bolt in the torque sequence, the center upper and removed it, replaced it and torqued it to the specified 22ft/lbs. Then did the same for the second thru the 10th. Then, when ask were in and torqued, I went thru and followed up with the degree specs in order. Hope that works, it seemed logical.
When installing the rockers on non - ported heads, is it necessary to use rtv on the rocker bolts? I've been searching, but can't find anything definitive. Thanks again.
Old Oct 31, 2017 | 07:22 AM
Suncc49's Avatar
Nope... I like to use alil anti seize though. Definitely not needed on non ported heads.
Old Oct 31, 2017 | 09:27 AM
Cool... thanks!
