Question on head bolts or studs
Old Oct 25, 2017 | 11:36 AM
LukeDowning's Avatar
Default Question on head bolts or studs
in reading a thread a bit ago in here about one of the members torqueing head bolts a tad too far and stock bolts being Torque to yield when I get ready to put heads on mine which ARP setup is better to go with or does it make a difference....Bolts or Studs?
Old Oct 25, 2017 | 11:48 AM
98CayenneT/A's Avatar
I went with studs just for the simple fact you don't have to worry about pushing **** through a water jacket because the blind holes were not clean enough.
I found head studs easier and nicer to work with in every way
Old Oct 25, 2017 | 11:52 AM
pantera_efi's Avatar
Default Studs = Block Life
Hi Luke, I would use studs, my studs work in a way as do the stock OEM Bolts, they stretch correctly.
The reason for studs is block bolt thread life, with a bolt causing the block thread to wear.
Would you like a set ?
Lance
Old Oct 25, 2017 | 12:18 PM
Lance
Thanks for the offer Lance but im still in the "trying to figure shi*t out" stage right now. still got lots to figure out I was just more curious on if there was a huge difference in the bolt vs studs
Old Oct 25, 2017 | 01:30 PM
Hi Luke, I do understand, it is good to do research first.
I OFFER, at no cost, an EAP Torque/HP report.
I would be able to answer more questions if asked, just PM you phone contact.
Good engineering is very cost effective.
Lance
Old Oct 25, 2017 | 01:32 PM
01ssreda4's Avatar
China studs, ARP lube, 25/50/75 torque sequence. Done.
Old Oct 25, 2017 | 05:35 PM
00pooterSS's Avatar
The OE bolts have higher tensile strength than cheap studs so ARP studs>ARP bolts>OE bolts>china ****
tensile test results in link
https://ls1tech.com/forums/generatio...ngth-test.html
Old Oct 26, 2017 | 11:02 AM
Default Head Stud Tech
Hi SS, good report.
The head studs tested china/oem bolts are equal in stretch, good for gasket life.
So I ASK, what are the last TWO studs to be torqued in order ?
Lance
Old Oct 26, 2017 | 05:44 PM
00pooterSS's Avatar
Hi SS, good report.
Lance
I honestly never have any idea what you're saying.
Old Oct 27, 2017 | 07:31 AM
01ssreda4's Avatar
Hi SS, good report.
Lance
Not 100% sure what youre asking so i will clarify. When torquing studs, I generally follow ARPs torque figures, and follow GMs sequence. Which means first pass over all large studs are 25 Ft/lbs, in order 1-10, second pass 1-10 50 ft/lbs, third pass 75, then go to the 5 small studs and they get 22 ft/lbs. Hope this helps.
I also dont buy into some of these tests. There is no doubt in my mind in sheer strength the china studs are NOT the toughest thing out there. But bottom line is a ton of people have used them with success on boosted motors which are notorious for trying to lift heads. They plain work, and Im not an engineer so dont ask for a detailed explanation of why, cause I dont know.
Old Oct 27, 2017 | 08:50 AM
Default Stud Torque Method
Hi reda4, thanks for your kind words.
NOW, my "tech" for the torquing method is as yours/GM with a LAST STEP #4 added.
That step is to "re-torque" the FIRST TWO center studs (1&2 middle) to 75+, just breaking sheer.
I find these two center studs at a lower value when this is done every time and know they should be brought back to 75.
AGAIN I AGREE "China studs are NOT the toughest", a good thing in this case.
ARP sells "undercut" studs for Race Engines, none listed for common LS application.
I have fit ARP studs but ONLY after I undercut these items using my Hardinge Lath.
The reason is to allow stretch, a amount equal to the AL head expansion.
When this is NOT done, the head gasket is "squished" each time the engine goes from cold to hot.
That term is called Extruded, when the gasket becomes thinner after use.
The good report from "pooter" states the China/OEM fasteners have the same strength.
This is why GM designed their engine, some good engineering my guess,
to use a head bolt that matched the AL head expansion.
Did I do better this time ?
Lance
Old Oct 27, 2017 | 10:26 AM
00pooterSS's Avatar
If it works it works is enough engineering for me. I frequently scratch my head at what "engineers" have come up with anyway. Being a tech your arch enemy is the engineer.
Lance
LOL yes, much better.
I figured you knew what the torque sequence was so I was even more confused as to why you asked about it.
Old Oct 27, 2017 | 10:33 AM
01ssreda4's Avatar
Lance
Thats interesting and had never considered that. I did notice, when recently using the new GM LS9 head gaskets (7 layer) on two separate engines that you can really feel them compressing. So much so that during the final torque round I was sure I had a stud giving way and about to snap. It had me very nervous the first time. All was well and it sealed fine though. Crazy stuff for sure.
Old Oct 27, 2017 | 10:39 AM
00pooterSS's Avatar
I've just always repeated the last part of the torque sequence on non torque to angle. For example I go back and start at the first bolt at the last recommended torque value and got through the sequence again. I also notice sometimes the inners go a little further. All the torque to angle stuff I do is stock motor stuff so it tends to act right just following the manufacturer's spec/making one pass at em.
Old Oct 27, 2017 | 06:34 PM
cookseyb's Avatar
After I torque the ARP studs, I put a old trouble light in the valley between the heads and cover the engine for 24 hours, then re-torque the heads. You will be surprised how much movement you get after this one small heat cycle. Many years ago we used to run the engine up to operating temp(breaking in the cam) and then re-torque the heads as SOP....
Old Oct 27, 2017 | 07:41 PM
Hi cooks, "OMG' YOU are SO correct, if I stated this "tech", I would have been PUT "high" on a FLAG POLE ! (hung)
John Drake "taught" ME this METHOD !
OUR "stance" is to TEACH, I thank YOU.
Lance
Old Oct 27, 2017 | 09:29 PM
Lots of good tech tonight! Thank you all! And good night!
Old Oct 30, 2017 | 09:58 AM
00pooterSS's Avatar
Very interesting, haven't heard of that one.
LOL Lance you wouldn't be hung. We just get confused by what you mean sometimes.
Old Oct 30, 2017 | 10:30 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Keeping it simple, the OP asked: "Head bolts or studs".
Unless you're making more than 20% over stock power, stock torque to yield are fine. They are one time use only.
Next better, ARP bolts. Follow their instructions for installation and torquing.
Next better, the best and pretty much required for high HP builds, ARP studs. Again, follow their instructions for installation and torquing.
When using bolts of any brand, getting the in-block head bolt holes clean and dry is A MUST in aluminum blocks. Failure to do so and you may crack the block. Not a bad idea to clean & dry iron block holes also.
Head and main bolts are mission critical fasteners. Import bolts often have questionable quality control. Stay away from them.
Old Oct 31, 2017 | 09:00 AM
AnotherWs6's Avatar
Me too. It's always confusing stuff followed by a sales solicitation.
